Hello Tom
Maybee you can give me some advice on my breakout board. I am designing a breakout board to translate the 3.3v signal pins on jp4 and jp6 to 5v. I was hoping to use the maxim max3002 bidirectional level translator chip to do the level conversion (I have a couple of projects I want to use the kflop board for and I was hoping to make a single board without committing the pins to either input or outputs at this point. The max chip seemed like it might be a way to do this.)
Anyways, I noticed in your writeup on step and direction setup that some of those pins have 150ohm pull down resistors, and I am trying to figure out a strategy to hook up my chip. I am no electrical engineer by any means, but I have designed and built many successful little assorted boards myself mostly arduino stuff, with an electrical engineer friend looking
over my shoulder.
My friend felt (without looking into my project to much) that the 150ohm pull downs would be a pretty strong pull down(do you agree), is there a way to turn off the pull downs or change there values?
Thanks for all your help.
Troy
